Technical Where did this fall off from?
blackpool
http://i.imgur.com/wlHvg.jpg
looks like a part of a bush or mounting (Radiator mount?) Its chucking it down with rain and dark so I cant see if anything is a miss but maybe some panda expert can id it straight away.
It's a lower radiator mount.
Seems perfectly fine. The white end goes in a hole in the supporting metal bracket, the black rubbery end goes in the radiator plastic housing. Easier to do than explain :)
You should be able to pop it back in by removing the 2 L-shaped brackets that hold the radiator at the top. Of course to remove them you will have to remove the grille first.
