Just wondering what everyone seals their wheels with after a good clean? Usually I would use Poorboys Sealant or similiar, but my GPS has the fork rims which are an awful design to clean. Cheers
Maybe you should be looking at this problem from a different point of view. Since upgrading my rear brake pads last year, to Ferodo DS Performance, the amount of brake dust they produce is easily 95% less than the OEM pads.
well for what its worth, I've been told from several people, two who do this sort of thing for a living...wax is wax [yes there are some good ones]..best way to go with alloy wheels is sealer
seeing as most alloys are finished with a 2k lacquer the same 2k lacquer that the car is sprayed with, then a good quality wax will prevent brake dust from sticking.
I use Bilberry wheel cleaner & clay bar where require to clean the wheels, then I apply 2 coats of Rim Wax. I find it make cleaning the wheel way easier as the dust does not stick as well.
