If its got a sun roof, its worth looking at that the seal has not gone. They tend to leak even if they have dirt trapped inbetween.
Also, check to see if the rear wiper jet washer works. These cars tend to have problems with the pump and ppl turn off the rear washer to give more power to the front.
As already mentioned, cambelt is the big thing, but also have a look at the rear suspension as these are prone to go.
Airbag light issues if an aftermarket headunit has been fitted.
Oh just to add, the factory meta alarms are real "crap". when the weather is hot, they tend to go off!!
Hey, make sure you check you have 3 keys and tags. The silver key, the blue key and the red key with tags. It is important you have the red key with the tags cuz if you dont you cannot make a spare key without replacing the ignition barrel.
Oh, as a tip, never leave the handbreak up during the winter as they tend to freeze up!!
Apart from that, these cars are Fantastic if looked after!!
