bluestripped
- Joined
- Sep 22, 2012
- Messages
- 23
- Points
- 10
Hello to all thanks for the inclusion. My query is one that a Fiat Dealer has yet to properly diagnose but having solved a static problem with the destruction of my remote central locking recently, all while I have spent £1500 on making my s reg someway to being a decent drive. I am left with now having the front shocks and springs replaced to finish the project but one niggling thing remains and that is the motor is hunting at times, fine at low revs but hold the revs at either idle or at 2K rpm and there is some loss of revs not by much only 250 to 500 rpm? and then back! I have had the HT leads replaced , spark plugs and throttle body cleaned and still this slight misfire continues. I try and solve it by releasing the fuel cap and from the resulting vacuum loss in the fuel tank there is some improvement at low revs. No hesitation of the motor at low revs results. Should I replace the fuel Pump???? or better still what should be replaced at 63K on a mark 1 Fiat punto 1.2 Sporting?I do also from time to time have a millisecond where all power is lost on the engine which as you can imaging in disconcerting to drive anywhere although not had any reliability problems, apart from the remote central locking. Looking out for your reply and valued comments on keeping my darling car tip top/
