Technical  what are the hoses called
qaz83885
uk
hi, in the uk what are the 2 hoses called coming from air filter, maybe breather and vacuum? can i i buy pattern ones on ebay
thanks
hi
on the fiat 1.4 doblo 2007 does anyone know how hard it is to attach the manifold end of the inlet breather hose [air bleed for the idle control valve].
i'm wondering if i need to remove anything if i do the job from underneath the van
thanks
Dear old-school mechanic, this car (1,4 8V) has no "IAC" valve. Check your other threads (one about throttle/"butterfly").
This is EVAP system solenoid valve. Yes, some on-line sellers have no clue and name it "IAC".
It shouldn't be hard to connect a hose.
