Technical Weird fuse box??
maxi26
Walvisbay
Salam wa aleikum :worship:
My uno 94' model 1100 have weird contact problem with head light and dimm light working after n light tab on the fuse box. and suggestions fiaters? :slayer:
Is it possible that the headlight fuses are loose and that the terminals need tweaking with a screwdriver? I'd start by fitting new fuses and also spray the plugs on the back with contact cleaner, unplug and re-plug them.
Also bear in mind that the fusebox may fill with water if the windscreen leaks, which will cause strange interaction between various circuits and functions - so look for signs of water damage.
-Alex
thx alex will have to unplug it totally and clean up or like you said to check the connectin pins. i have replaced most of the fuses but still to no avail.
Cable (Red colour) that supply power to some components of the fuse box as worn out abit,dont know how this is even possible,fix it up and no more problems with lights.
Topic Solved!:
