Technical Water ingress in cab
lakeland
Had this problem for quite a while, thought it had been sorted with new seal on overhead cab window and tightening catches. With the current very heavy rain have noticed rail water around the base of the gearstick and dampness around the cab light above. Any ideas where this may be coming from?
Front window seal? , do you have anything cut into /mounted on the roof? have you checked there seals, any rust, gaps etc.. water ingress is terrible to fix.. as it travels all over the place..
Thanks for replying and the suggestions. We have a solar panel stuck to the roof and factory fitted aerial. Unfortunately I can’t look at it now as have given up for now and have covered up for a couple of months
