DoIDon'tI
- Joined
- Feb 17, 2008
- Messages
- 470
- Points
- 81
Well, two warnings really:-
1. When the aircon drivebelt needs changing (72K), get the garage to do it. The cambelt is easy compared to this.
2. Your car has an oil cooler, it's behind the RH (looking from the driver's seat) lower grille in the bumper i.e. below the RH headlight. It is alloy, and has steel pipes going in to it
. When I saw how much corrosion there was round the pipes I was shocked; needless to say they are now covered with waxoyl. The 2.4 is the only Croma to have such a cooler, so the only place you will be able to get parts will be Fiat - the cooler alone is over £100 and the hoses will be similar, no doubt.
More to the point, if it corrodes to the point where failure occurs, the first warning you will have will be the low pressure light on the dash, and the damage is done by that point. So - get under your car, drop the small access panel in the undertray immediately behind the bumper (not the main undertray) and shine a torch in - a little action now could save a big problem later.
I should have bought a 1.9...I'd still have skin on my hands :bang:
