WANTED: replacement front o/s window switch
J
j100sx
Hi all
Can anyone suggest a source for a replacement front o/s window switch(just the passenger switch control is knacked). Fiat have quoted £48 + VAT! and I haven't had any luck at the breakers.
*Edit:title added*
Re: Untitled
hi, if u wait for Scotty to pop online, he will have one. alot cheaper.
Its a 1.4 Chassis, 1.6 Engine and 2.0ltr Brakes and half a Marea :)
Follow My Project
Updated: 06/07/2008
window switch/ engine management light
Thanks for that - also I've just changed the plugs (should have done it before) and although the engine sounds smooth the engine management light has come on - is that normal and will go out with use or a problem?
Re: Untitled
its not usual...but they cpme on and go off as they wish really
Follow My Project
Updated: 06/07/2008
Re: Untitled
I might have one lying around, I'll have a look and get back to you!
Engine management light should not be on! The ecu is reading a fault somewhere!
window switch
hi looking for window switch for fiat bravo year 2001 the main one witjh two swittch/ lost with it thanks Frank could also give a little advice on how to fit this. maney thanks
K
3
437
K
C
7K
Carroll
C
L
1
762
Tommy K
T
L
407
L
