General Wanted Mk1 Uno Front Door Speakers
I may well have, I've got a few speakers which came out the Uno - will check.
Were they made by Fiat, would they have a Fiat Sticker or another manufacturer? Also do you know what physcial size they are?
which actual size speaker fits into those holes? i'm thinking about restoring my door panels as they look like crap, falling off and all. wanted the original size as i managed to half put in some old 6 inchs i found, which definetly don't fit, that could be why the door panel wont hold...
These are to fit in the door pockets that were fit on the uno SX and turbo models not sure if the rest off the uno range came with these door pockets.
Grundig 7w pod speakers
I found pre-drilled holes and pattern in the masonite board on my 3dr MkI. It is visible only after you remove the black plastic foil covering it. I am not sure about the pattern diameter as I did not use these - I found them only after drilling new holes for my speakers.
I did not like the idea of fitting the speakers into the pockets (ingress of dirt etc.) and used the provision on the rear plastic shelf supports instead. These, I believe, are for 100 mm speakers. It was a solution satisfactory for radio - I have no desire of running a disco on wheels - and removed them only because I needed more room in the trunk.
Yes thats where the fiat speaker accessorie goes where the pre drilll holes are just wondering if any one has these for sale?
