Styling Want to change my steering wheel..how easy?
peterp
United Kingdom.
Can anyone help me on changing my steering wheel on my 93 Uno to something a little sportier..
Was wondering how easy it is & will I need a boss.
Are there any recommended steering wheel links etc.?
Thanks for any advice
Pete
But does it have to be an Uno boss....??Its a 93 plate -if that helps.
Pete
Petep
Taking it off is easy carefully prise off the horn cover then with a large socket remove the locking nut.
Then pull the wheel off the splines maybe a bit tight.
The problem you may have with a new wheel is the indicator cancel nipple may not correspond, just means you will have to do it manually each time.
Pete
A mk2 Uno turbo steering wheel will bolt straight on, BUT, you MUST get the boss that comes with it. The wheel and boss where standard fitments on all mk2 Uno turbos. It is a nice Momo leather rimmed wheel as well (y)
If you can get the turbo boss, it looks like it uses standard bolt spacings for the steering wheel, and I suspect that many aftermarket wheels will fit this boss too.
I saw a mk2 Uno Turbo Momo wheel on Ebay the other day go for about £20 I think. Look around and you will find one ;)
