Technical Various complaints/ DIY tasks
crosstown
The car is an '08 1.4 90hp with 50k miles.
None of my centre console lights for my fan controls are working. It's the standard fan not climate control. Am I right in thinking I have to pull the glove box to get to the fuse? I found the guide for the light replacement but it looks like a pain in the behind to to check the fuse.
I have a tick-tick-ticking coming from my ventilation fan. Is this a common failure? Is it something that can be fixed/ lubed/ cleaned? Is it a pain to remove and diagnose?
There's a kind of low volume whirring/ turbine type noise is how I would describe it from the engine. You can hear light rattle for a second or two on start up and then it quietens immediately.
The pitch of the whirring increases with revs but the volume stays the same. You can hear it at low speeds when the engine is under load; in traffic with the windows down or when driving down a narrow street with the noise reflecting back. You can barely hear it if the engine isn't under load. In general, there's also a ticking type noise maybe a pulley bearing chattering or something like that.
The noise changes very little with the A/C on or off. I do notice that the A/C probably needs gassing- it's not the coldest. Maybe the noises are ever so slightly more audible with the A/C on. I know the whirring and the ticking noises are likely related. The car is driving fine otherwise. I had the timing belt changed recently and the noise was the same before and after. Unfortunately, I forgot to mention them to the last mechanic before he did the job.
There's also a clack noise from high up in the right rear suspension. I know there was a recall for the rear body welds but I think I'll need to get this looked at professionally.
Any thoughts or comments appreciated. There aren't many specialists in my area so I'd like to be as educated as possible before giving my car to someone who isn't likely to have handled one. Thanks folks :)
I have a 1.4 90 too, now done 100k no major replacements . Our roads around here are even worse than ROI rural roads so its had some hard work at times. As for your list........................
A: its possible the panel lights have blown there is a guide on this forum for how to replace.
B:Turn your fan speed to maximum just to check you dont have a leaf stuck inside. Fast speed usually shifts them.
C: The whirring noise could be the waterpump. Did you replace this at the fanbelt change. ? The pumps can be noisy , even from new in my experience. At 50K it would have been sensible to replace it.
D: Suspension noise, most of the replacements were for very early models but it could be yours was hanging about before registering. Best check with a Fiat dealer so see if yours (vin number) should have been recalled. Otherwise check for obvious causes like loose stuff in boot and wheel bay, parcel shelf rubbers missing, leaking shocks, banging exhaust, broken rear exhaust bracket.
E: Donate to the forum !! and you wont feel guilty when you post another long list.!
