P
Phill
Ok, I need some help. Have lots of minor/major problems with my broom yellow 1.6 hlx that I want to start trying to sort out so would welcome any useful advice. Sorry for the long post.
1)the bonnet paint work has been rubbed in certain areas with an abrasive cloth leaving small patches of whitish colouring. Is it worth using a t/cut or polishing wax on these areas and if so wich one is my best bet.
2)the common peeling on wing mirror base plates. Should I hammerite them or use plasticote matt black for a better looking smooth finish
3) my car often overheats if sat in traffic for longer then 5 minutes. Water levels are fine and im fairly certain that the fan kicks in. What else should I look at?
4)have a leak somewhere from the sunroof or windscreen seal but can't find it for toffee. Front left roof panel gets wet and water seems to run right down to under the glove box. Any suggestions.
5)My alarms buggered I think because the sensor has got wet. Will it be worth taking out and drying it and if so is it the big battery looking thing in the central light panel.
Any advice would be useful. Cheers.
