Technical used tipo
Technical used tipo
dr_dreaduk
hello i recently lost my job and having a company car lost my car!! (gutted) now ive been given a tipo that needs brake pads and im told a seal for the power stearing! now im hoping to pick it up sunday! if anyone can tell me if the power stearing is a major problem or what i should look out for!!
thanks
simon
Be careful of
Dying Clutch (old so likely to need replacing if not already changed)
Leaking Rear Brake Drums (look for oil on the wheels or have a feel)
Steering Rack for the power steering. check the rubber covers they should be covering it and check for fluids.
Oil leaks are normal :p but if the engine has been steam cleaned is likely the rubber seal will need replacing.
Check the water for traces of oil or foreign subtances.
Check Shock Absorbers, bounce test will do.
not much more i can think of apart from the obvious body work and electrics.
thanks mate do you think if it leaks supposedly from a seal around the power steering thats gonna be a big problem?
Well unless it can be easily fixed it might be a serious problem.
Power steering uses the Hydraulic fluid, so does your clutch and so does your brakes. I'm not sure if its three seperate systems or if they are all linked somewhere.
if the pressure gets low one day you either break down or drive into something.
when my clutch fluid pipe ruptured I often had trouble stopping, I thought the brakes needed bleeding but I just had low pressure, fortunatly the clutch packed up before the brakes did so when the pipe was replaced everythin was ok (y)
