USB won't play
USB won't play
ravenblue
Hi guys.
I have been driving a Punto Evo for 18 months now and have used a 8gb USB through Blue and Me for most of that time and rarely had problems (occaisionally it would freeze on a particular track and cause the library to mess up song information, as if it had removed the song and data had jumped up a file. However by deleting the song that caused issue, it was back to normal.)
Unfortunately, When I plugged the USB in this morning after putting some new albums on, it will not play. The files (including new ones added) are all there and can be scrolled through, whether through steering wheel controls or on the stereo, but no sound whatsoever plays.
Not entirely sure what the problem is as the radio and cd both play fine.
I have tried removing all files, putting them back on, as well as using a different USB stick and again, it's recognised the folders and built the media library but will not play anything.
Is anyone familiar with this problem or have any ideas of a solution?
Thanks.
The stereo and the blue and me are two different boxes. Blue and me is an external input to the stereo.
Do any of the other sounds (the bong when you press the windows button, or the blue and me speech) work?
Does the track name come up on the stereo display when it is playing silent?
Thanks for the reply.
Yes, the Blue and Me voice is still working fine, both noisewise "Please make a selection" etc and voice recognition- I can press the button and say 'play anything' and it will randomly select a track from the USB but still no sound.
That proves the stereo input is being selected and working, that the wires are OK and blue an me is capable of making sound.
It is either that is is not happy with the media files, or it has got is knickers in a twist (it is running a microsoft OS after all).
To untiwst it's knickers I'd try a reboot, by pulling off the battery earth lead quick release for a few minutes.
I need help with mine to needs a update, please can someone remind me how to do it???
Stz
