The uno turbo quick rack is 3.4 turns compaired to the 4 turns lock to lock on a normal uno,worth changing if you can find one imo.
Not that my test was fair as i had shorter overly stiff spax shocks at the back and stock shocks at the front, but when i lowered my 45 with spax 40mm springs the front sat way to high and i ended up having to use some -60mm's i had laying about on the front to get it to sit right.
Also if you try -60mm's on the back it sits about 1cm off the bump stops.
This was possibly due to the weight difference in the engines?
Also 60mm springs in the front dislocate from standard shocks by a vast amount when jacked up and is an mot fail.
I am hopeing just to use normal 70sx shocks on my 45 once its been converted to turbo,as i want a sensible ride and the 70sx shock were cheap.
You get an uno to stiff and it turns in to a horrible car to drive on ****ty british roads, crashing about everywhere.
God knows how i will get on with the 70sx shocks but thats the plan,but i am not looking for an all out handeling car nowadays really.
With the above 60/40 setup with the stuck on pretty stiff spax rear shocks and stock fronts the car handled terribly.
It would lift off oversteer real bad and was just all round crap tbh,on hill brows it would jump you out of the seat due to the too stiffer rear end.
On my old uno turbo though i had a full set of adjustable avos and strut braces and that thing used to handle brillently,no lift off understeer at all and very very predictable with understeer all the way, but it would always tuck in nice if you eased of the power.
It was still a bumpy horrible ride though tbh.
Tyres have a lot to do with it all though, as my ones at the moment are gt ditch finders lol,a good alignment setup can also make a world of difference.
Strut braces are also a good idea imo,but its hard to find a rear one that bolts to the turrets and not the shock tops for an uno,you end up having to make yourself one like i have had to.
Here is how the 45 sits with the -60/40mm drop,its still a bit low at the rear compaired to the front.
