Upgrading wiring for component Speakers
S
Sy
Wanting to install some new speakers soon, I have got an amp for them already But as a previous post i need to upgrade the wiring, How do i do this? Where can i run the wires into the doors as the connector there seame sealed?
Cheers All Sy B
your eyes are as good as ours my friend, not a lot of options apart from drilling a new whole and putting a gromet in it
Re: Re: Upgrading wiring for component Speakers
i did this a few weeks ago, just drill a small 3mm hole in your door feed the cable through and then when u are done put a little silicon sealer on it and bobs your uncle.
the rubber bung around the wireing loom comes free if you pull it, then slide the wire alongside the bung and when you pop it back it is forms a tight seal.
any problems drop me an e-mail and i am sure i could help you out, you just need a pair of balls to drill you car, lol
ps, use maskin take to stop the drill slideing when makeing your hole.
Re: Re: Re: Upgrading wiring for component Speakers
i just cut the old wire just inside the car and fixed the new speaker wire from the amp to in.
TAFI
A
1
11K
Angelo
A
5
851
Darren
A
993
A
