Technical Uno Turbo
Technical Uno Turbo
Verve
I am busy replacing , head gasket,rings,bearings,clutch,shocks
Completed fitted the go tech.Body work great. Interior needs attention.
Turbo in very good condition. Hope to get 1.0 to 1.2 bar boost after everything is completed. Not sure what injector size to use , if the turbo would be capable of supplying this type of boost and if fuel pump would deliver enough fuel.
Verve
MK2 , thank you for the info , worried a bit about the go tech , dont know how to adjust this correctly
go tech?
Standard turbo will be very unreliable over 1 bar boost. It also wont make any decent power either.
