sdlsaginaw
I have a Uno Turbo Mk1 engine and I'm looking at Megasquirt for fuel and ignition control. I don't know at this point if I also need to control boost or not. I plan on running it at .9 bar.
I think I want to go with the V3 board due to better noise immunity and short protection. I also think I want to use MS2 for the higher resolution tables. I'm not sure if these are good choices or not for this setup, as I've read that MS1 supports things that MS2 doesn't and visa-versa. It's still a bit overwhelming.
As I'm missing the harness for the Marelli ignition module, I need advice on the best alternative too. I've read a lot of trouble getting Ford EDIS to work, including some very MS-smart people just giving up on it. I may or may not use the flywheel trigger, it depends if I need it or not for the suggested ignition. If so, I'll have to adapt it to the X1/9 transmission case.
Are the injectors low or high impedance?
Are there existing maps out there to start with?
Looking for any and all advice!
