turbo_jim
Ive got a problem with my turbo which i'm pretty sure is down to an air leak. It keeps cutting out at idle and if you put your foot down hard it gets to abt 3k and gives up. If your gentle with it it will rev right up to 5k-ish, but im only gettin 0.4 bar boost max as opposed to 0.75 before.
As I said, I'm fairly sure it leaking air, but where is it likely to be leaking from? I cant see/feel/hear anything obvious from under the bonnet. Air flow meter seems to be working correctly, other things that have been suggested are wastegate valve and various gaskets. Anyone got any ideas what i should check first??
cheers, Jim
cheers, Jim
