General Uno Turbo head
Aceuno
Can anybody tell me how many cc's is in an mk2 uno turbo head?
Take your bore x stroke that is in mm, convert that to cm.
then use this equation, 3.14x half of bore x half of bore x stroke. then you get the cc's of one cylinder, Divide that by the compression ratio, then you will have the size of the combustion chamber inc the head gasket.
... which is quite a lot relative to some of the other engines in the family!
I measured (with a flat piece of plastic having a hole drilled in it, and a pipette) the capacity of a FIAT 128 1116cc cylinder head - 32cc - and a 1290cc cylinder head - 34cc. I would expect the apparently-identical Uno 1116cc and 1301cc engine heads to have similar capacity. But the Turbo is obviously quite a lot larger (to give that lower compression ratio).
EDIT: One obvious assumption that calculation would make: that the piston goes all the way to the top of the bore, and that the piston has a flat top. Unfortunately, neither of these is necessarily true (the FIAT pistons always have valve cutouts, probably 2-3cc there, and in the N/A 1301cc engine the pistons don't get to the top). But on the whole, I think it gives you a fair idea (why do you need to know?) ;)
-Alex
