General uno turbo engine...need advice
is ur uno a turbo already? if not either will be fine and will bolt in no probs. u'll then have to use either a mk1 loom or mk2 loom depending on ur engine choise. its said that the mk1 1.3 engine is stronger, but in this case id prob go for the mk2 engine which is the 1.4 one as urs is a mk2 car.
Dunc
yeah u'll need to swap the suspension.
u'll need.......
1.4 UT engine complete with manifold and turbo, downpipe etc
UT airflow meter
all pipework, both water and air
drive shafts
front hubs
front brakes, calipers and discs
gearbox
complete wiring loom
radiator
intercooler
dash clocks
suspension
steering rack
gear linkage
UT exhaust system
other things u might change if u wish (reccmended)
rear brake calipers
rear brake discs
rear UT hubs
rear brake caliper mounting plates
prob more, but thats a list for starters ;)
Dunc
