Hi Everyone,
Here's my next problem with the Uno I've grown to hate
Ok, symptoms. Once warm if I put my foot down fully, regardless of what gear I'm in (although it tends to get worse the higher gear I am in at a lower speed i.e. in 5th at 30mph) the car stutters, judders and holds back. If I let off the pedal a bit, sometimes it will accelerate slightly smoother.
This only ever seems to happen most once warmed up, but before you say it, I've already changed the plugs and leads
I've had this before when the headgasket was on its way out, but thats been replaced and shows no signs of going again.
If I'm honest I'd also guess that the alternator is on its way out, I get the odd flash of the battery light when the indicators are on etc, but in a typical fashion I've managed to ignore this up until now and pretend that theres nothing wrong and perhaps the car is just trying to communicate with me
Having never suffered from a dodgy alternator before, I'm led to believe that this may cause the symptoms I've been having, but am not sure.
Obviously with this being a cheap runaround I don't fancy changing parts left right and centre, so has anyone got any ideas where I should start?
Paz
Paz
