Hi every one
I am a newbie in fiat Uno
, I just bought the black (1991 1.4 ie) Uno 6 weeks ago.
Unfortunately, I am having a problem with my uno from the beginning.
It was having a problem when I first bought it, the car starts normally, but when its warm it acts like there is no fuel and finally its go down.
The technician from the repair shop said that it’s the fuel pump fault (low pressure), it had a 1.5 kilo ( I don’t know kilo what !!) fuel pump. He said that it must be at least 3 kilo because the pressure regulator in the carburetor will not open in the 1.5 kilo and the fuel will not return to the tank by the return pipe. And if that is the case the trapped fuel in the carburetor will be heated and will evaporate and form a gas bubble!!
Therefore, he changed the fuel pump with a 4 kilo and the problem was solved.
My problem now is the bad economy, really bad economy ( average 5.5 km/l), I changed the sparkplug but it still comes back black.:bang:
I did some research on the internet ( and that how I found this great forum) and I found that the fuel pump for the Uno is 1.1 bar.
So I am confused now, is the high pressure that is causing the bad economy? or not ?
Or its may be not the fuel pump fault from the beginning and it’s the pressure regulator ?!
Any help will be very appreciated.
Thank you
Sorry for my bad English.
Thank you
