Technical Uno MR2 dashboard
jte
I have MR2 Uno 60IES, ít has dashboard with speedo-, temp- and gas gauges. I also have dashboard from MR2 Uno with speedo-, temp-, gas- and rev gauges. I like to know that are these dashboards interchangeable.. Are all connectors the same and does the wire from rev counter exist in the connector? Can I take the old dashboard away and put new dashboard in and plug all 5 connectors and all wiring are in right places?
Thanks Juha
Assuming the mk2 dashboard is similar in principle to the mk1, the yes, as M@nticore says it will swap over no problem and all the connectors will fit. The only thing you have to do is run a wire from the low tension side of the coil to one of the connections on the dashboard to make the tacho work. Like M@nticore, I can't remember which one it is either :eek: I can't check because my Uno is in another continent!
