General Uno Mk2 turbo dashboard
Daleyboy10
Rugby
will the uno turbo mk2 dashboard fit and work on a fiat uno 60s?
cheers
Dale
the dashboard is the same just with different bits added here and there!
if your on about the instruments (clocks) then they go in, just need to hoook up some of the extra dials/guages but obv. boost guae aint gunna work :p
Boost gauge, oil pressure and oil temperature won't work without the appropriate engine sensors, and obviously you will need a turbocharger to get the boost gauge working ;)
The tachometer only needs one wire connected to the low tension side of the coil to work. Louie did a post/ guide on how to fit one to a lesser model Uno - use the search facility and you should find it. (y)
And as Unonumero says, the dashpod itself will physically be a direct swap with your existing 60S instruments. No real issues with fitting other than to make sure no wires are trapped and that the speedo cable is fitted correctly.
Good luck! :)
Thats great cheers for your help.
in time i will eventually be dropping the 1.4 turbo engine in it so yeah.
(y)
thanks.
Dale
