Removing the glass is pretty easy (especially on the front windows). Steps:
1. Wind the window down
2. Remove the rubber seal from around the top and sides of the window (it just pulls out).
3. Remove the two rubber strips, these are a bit tricky. You need to reach in with a screw driver (I have a specially bent screwdriver for the job). There is a little track right at the bottom of the plastic part, if you reach in from above with the screw driver you can pull this track towards the middle of the door which releases it. It takes a bit of digging around until you find it, and you may wish to get a bend screwdriver like I did.
This is the point where you could fit the tint, or...
4. Remove all door handles, then remove the door card.
5. With the internals of the door exposed you will be able to see how the window attaches to the window winder mechanism. It will be one of two types.
a. A big metal bracket that can be unscrewed
b. A white plastic clip that pushes through a hole in the glass, this is a bit tricky to remove. You need to push the two tabs together and then push the clip back trough the hole in the glass. This would be easy, except the clip is on the other side of the glass...
6. Now just lift the glass out of the door at an angle.
Reassembly is the reverse of removal...
