Hi.
Q: Are the two fixings that hold the DRL cover in place screws or bolts going into a captive nut?
The offside DRL bulb has blown but I'm unable to remove the cover as the two screws/bolts are seized up (nearside is in the same state).
The philips head slots are corroded and the cover is too flexible to get any pressure on to them.
I can't use mole grips as there's no lip on the screw heads.
All I can think of is to carefully cut the heads off and then remove the stub of whatever's left over. Knowing what's behind there would be helpful.
Any other suggestions?
