General Tyre wear,
General Tyre wear,
You should be able to adjust camber on the rears not 100% certain on our bravo's, also did you check your tyre pressure? could be a slow puncture/low pressure or even the valve could need replacing. If tyre pressure ok, then go for a 4 wheel alignment check, have you hit any curbs/pot hole recently?
Have a read:-
http://www.atseuromaster.co.uk/wheel-alignment.htm
I don't think there are any adjustments for the rear wheels on a bravo. Tyre pressures are checked weekly and corrected when necessary, there's definitely no leak I've gone a month without needing to blow up tyres as they were all at correct PSI. I've not hit any pot holes myself, though I have bought the car second hand so can't say that. A previous owner hasn't. Can a good tyre place check the camber and alignments of rear wheels?
