Ok, dont worry, its nothing really serious but its there and its more of a pain in the arse more then anything although ive learnt to drive around it so it doesnt happen anymore heh but i still want it fixed
basicly,
the engine cuts out if you quickly let off the throttle when on boost. It doesnt completly die at first but will drop the revs as normal but instead of stopping at 1000rpm and idling normaly it will just cut out.. starts perfect again once its cutout.
Ive at first I thought it was just random but ive worked out that it will only cut out if you come off the throttle when you have been using boost. can just be a tiny bit of boost (as in a slight over rev when moving in traffic) or a bit lot of boost (as in 0.7 bar at 120mph)..
If you dont go on boost then the car drops and idles normaly and is fine.
I dont know if its anything to do with it but I know the car is overfueling as it was setup and tunned to run 1 bar but has now been returned to standard boost. Would that possibly cause the cutting out?
Apart from this, the car drives, boosts and revs perfectly so I doubt its a boost leak etc as the car would suffer elseware
Anyone any ideas of what I can check as im lost
Dunc suggested the idle sensor thing but i cant see why a faulty one of those would cause it to cut out on boost but be fine off boost...
help
basicly,
help
