I wonder if anyone can help me? Have been running a new bottom end in this car for 3000 miles now and is running v well, except for daft amounts of smoke on acceleration (even for this engine) but also general exhaust stink e.g. when just pottering along with the sunroof open. So a couple of questions...
Thermostat? The indicated temp is always just above cold. Please can anyone explain - is there a thermostat and what does it control, e.g. is it just the fan or does it take the radiator in/out of the loop? I suspect it might be running too cold - altho then again with 2 different heads and the old bottom end it has always run this cold.
TDC mark on the crank sprocket? When putting in the engine, the TDC mark appeared a good few degrees off actual TDC of pistons 1 and 3, hence I compensated 4 this with the timing belt. Can anyone say whether a basic engine like this will run passably, albeit smokey with, say, a tooth out crank v cam as I have wondered if I over compensated.
Thanks for any help you can give.
