Just wondering, Kristian and Craig; how do you go about tuning your VE and spark tables. I'm running tables that are loosely based on Kristians, but feel the engine is not as quick as it should be. How much igntion advance can i push before det becomes an issue, and i can get a few more deg by adding a little bit more fuel, yeah? Am aiming for an AFR of 13.2, currently using AFR target tables and EGO correction - but want to map away from that.
Do you use autotune? I've faffed about with that in the past but kept getting vertex out of bounds errors.
