Tuning Tuning a abarth
Pmarkm
I bought a 2012 abarth that the old owner must of had tuned and exhaust done. The tune in it now produces 22lbs of boost. I was wondering if I could put a stock tune back in so it doesn’t over boost and blow engine again? I see that it is catless and has aftermarket up pipes and blow off valve. I just want the car to be reliable. I use it to push my drag car at the strip. I worried about over boosting the engine and blowing it up.
I’m not worried about a check engine light coming on because of the no cats.
Thank you
I can put it back to stock tune,but I’m not sure if it will run right because of catless exhaust.
The present 595's with 145 hp can be remapped to ± 175 hp and the 165 hp version (same engine -Turbo as the 180 hp) can be mapped to ± 200 hp without any issues.
You can always go to the remapper of th car (if you know it) and ask for a more detuned map to be installed.
