I'm trying to repair a few faults on my 1991 Tempra SW 1.6, carb model.
Main problems are :
-idle woes : idle rpm gets up and down, engine will sometimes idle, sometimes not, sometimes idle is at 1300rpm and sometimes the engine simply stalls when below 1500rpm ; i'm currently rebuilding the carb using lots of cleaner fluid (the p/o didn't use the car for about 1yr and lots of deposits have always been removed but i fear some crud can be blocking holes in the carb.
-front wipers : they don't work. they just move a little up and down (1cm). p/o told me he replaced the motor from a scrapyard but didn't get the right model. i suspect linkage badly out of sync but can't be sure until i dismantled everything.
-i have electronic dashboard (SX model) and the warning light for 'open tailgate' remains on whatever i do. i checked for ajar sensor but only one i found is in the tailgate, behind the trim (sort of level sensor with a ball inside) ; this works well and interior light goes off when i close the hatch. Is there another sensor for the warning light? does anybody have an electrical schematics for tempra check control? i have several schematics from haynes and porter manuals, a few other ones from a local tech book, but nothing related to this feature.
Any help greatly appreciated.
Regards,
zp*
Main problems are :
Regards,
zp*
