M
Morgan
Got a troublesome 2000 Bravo 1.2. It has been on a diagnostic at a Fiat specialist and it is running rich. Although not well looked after by the garage of the previous owner, I have done a fair bit of work. The pressure sensor and stepper motor were changed shortly before I bought it, I have since found it had the wrong plugs, the cambelt had been replaced but was out by a couple of teeth, the coil and leads have been replaced, along with the lambda and the temp sensor.
The lambda was covered in black soot, so its rich for sure, but that was before I replaced the coil pack that missed out No4 and No1 cylinder from time to time.
The temp sensor change has made things better, it runs about 8 miles before the red 'injector' light comes on whereas it used to do that after 3 or 4 miles. The only other fault is that it does not run at higher revs when cold, struggles to keep going without blipping the throttle.
Any idea chaps on how to sort this car out once and for all? Suggestions welcome.
