Technical  Towbar electrics
dmcchris
llanelli
(y)does anyone know the colour wires in the van i have double electric plugs on the tow bar and need to wire it up
hi
just done single electrics on mine, take plug out of rear r/h light and just probe for wire function. You will have to run a couple of wires from the l/h light connector. My first bypass relay, cheapest I could find on ebay didn't work, purchased a larger bit more expensive one and it worked perfectly. Make sure you get a good earth, there is a permanent live connection next to the battery if you need to use it.
