Hey forum!
I really want to keep the stock box if I can. Gears are solid.
I don’t need mesh - not shifting.
I just need strength for one gear of torquey madness.
Good news - 25mm drive shafts already in there.
I don’t really want to go in and shim this diff to have it get loose again. Is that likely?
I trimmed off the top bolt of my bell housing so would love to avoid the 126 housing swap.
Can I stick with this box as is and just beef up the diff?
Is that an option?
Is this not the diff at all?
What would you do?
If you’re curious, here’s a deck on the build.
Play by play is on my insta here.
Thanks!!!!
- Very grateful for all the wisdom here!
- My 69 L now has a 67 hp, 106 ft-lb Zero Motorcycle motor and 13kwh battery aboard (~90 miles range). All supporting cast came along for the swap: controller, twist throttle, charger, dash, even the 12v cig lighter circuit is charging the stock 12v battery.
- It’s a hoot. Running without clutch. Pick one and go, third still spins the wheels and works best. Heat from staying m in one gear seems to be ok so far.
- BUT… Diff sees to be struggling.
- I’m getting loud clunk sounds in every gear on engagement.
- It skips out of traction under heavy load.
Is that an option?
What would you do?
Thanks!!!!
- Model
- 500L
- Year
- 1969
- Mileage
- 300
