anyone had symptoms of no dashlights,headlights,indicators,wipers,horn etc
i have had this problem on my uno45fire and a friends uno75,its strange as the hazards still work.
anyone with any of the above symptoms,i recommend the following:
remove the 3 screws from beneath the ignition panel and slide off the bottom plastic steering/ignition housing,on the back of the ignition barrel housing are 3 or 4 wires,turn on the indicators and wiggle the 4 wires on the back and see if this solves your problem.
if so,use a pair of pliers to crimp the metal terminals securely onto the housing.
i had the above symptoms and a fiat technician couldnt fix it!nor could another backstreet garage.
simpler than it sounds and have had no problems since!
good luck
good luck
