Hi all,
I`ve just inherited my parents 71000 mile 1993 Fiat Tempra 2.0ie SX estate with the twink 8v engine which they`ve had from new as they`ve just got a`new`55 reg 1.6 Stilo SW(which I`m very disapointed in), Its externally mint, but is pretty tired all round which is why they decided to change it.
I`m intending modifying coz I think it`d be a funny street sleeper! I`ve heard of people fitting Delta integrale running gear(including 4x4 gear) into the Tempra! Apparently there were 4x4 turbo models in Europe too!
Eventually I`d like to fit either nitrous or a Delta`s turbo system....
But 1st things 1st... I want to do the suspension ASAP as its the worsed & most worn area on her. Its had new standard gas shocks & still find them too soft, being high it rolls wayyyy too much (I`ve had the rear end drifting at motorway speeds with 5 people inside).
It also wheelspins rediculously easily in the dry, let alone in the wet.
Now I know the Tempra shares its chassis with the Tipo, Landia Dedra & Alfa 155.
I also understand it shares some major suspension components with all those, plus the Bravo/Brava, Lancia Delta/Prisma & the Alfa 145/146 ranges.
I was wondering if any of the harder shocks from those other models would physically fit my Tempra`s fixing points & if so, which do you recomend.
Also, roll bars, would the thicker roll bars from the other cars fit, again, has anyone tried it.
Also polybushes, are there Tipo ones available? they should be a straight swap.
Brakes arent too hot either, I`ve got a feeling the servo isnt working properly, its a pre-ABS model. Has anyone got a new Sei one? is it bigger?
Has anyone attempted this kind of thing before on their Tipo?
Cheers!
Paolo
Cheers!
Paolo
