mr_lizard
I'm hoping that the experience of everyone on the forum can help with a problem I have with my Tipo diesel. The car is a 1994 on an M-plate and has the 1.7 non-turbo lump (engine code 149b4?)
Since I bought the car in april, i have covered about 1500 miles and have had no problems, despite the car having 118,000 miles on the clock. All hoses, belts and wiring seem to be in good condition.
My current problem is the car has suddenly (overnight) developed a starting problem. Last week the car started fine and I did a long journey of 180 miles. The next morning the engine will not start, and the glowplug light comes on and goes off immediately. The engine turns over on the starter fine. Had a look on the web (including this site) and found that the glowplugs were possibly at fault. Bought some new plugs but had insufficent tools with me to change them, and ended up calling out recovery who got the car started immediately using the Easystart trick. Drove the car back home again 180 miles with no problems whatsoever, and starting was fine once engine is at temperature (say 70C?).
Been looking at this over the weekend with a view to changing the glow plugs, but access is restricted by the fuel system and it looks like I may only be able to change 3 of the four plugs. Have tried to use a glowplug ring spanner with ratchet to remove the plugs but I cannot shift them, and do not want to damage the head as fixing the damage would be more than the car is worth. Anyone have any advice on how to change these easily???
When I try and start the car now, the glow plug light comes and goes off immediately, and you can hear a relay click as the light goes off. The click seems to come from the passenger side of the car. Have looked in the engine bay and found a unit mounted to the rear of the battery tray that appears to be the glow plug relay. The unit seems to have positive and negative feed to it, with the third wire (brown) going to the glowplug bar. I'm assuming that this is the relay. The unit has some text visible:
Fiat/Lancia
A131
CCD 17
12V
Is it possible that that glowplugs are actually ok, and that the relay is the problem? Any ideas on price for a new relay?
I need the car running again, but money is tight and I do not want to try and force the glow plugs if is possible that they are ok. The engine will fire with Easystart and will run fine, and provided the engine is around 65-70C or higher it will start ok and run fine.
Apologies for the long post, just trying to cover everything that has happened and what I have done. Look forward to your thoughts...
Thanks,
Tony
Fiat/Lancia
A131
CCD 17
12V
Thanks,
Tony
