T tg050746 New member Joined Sep 3, 2006 Messages 1 Points 1 Sep 3, 2006 #1 I ve got a 93 k reg tipo but the clutch pedal is going to the floor as I drive along you can hook your foot under to pull it back and is ok for a while any answers thanks
Hellcat zombie nation Parked in the garage Written a guide Joined Jul 8, 2005 Messages 28,510 Points 5,372 Location on the A684 Sep 3, 2006 #2 Either failed clutch slave or master cylinder. Check for leaking oil under the clutch pedal or around the top of the gearbox.
tipoboy New member Joined Apr 20, 2006 Messages 178 Points 39 Location perth bonnie scotland Sep 5, 2006 #3 had this problem a few months back does your clutch work again after you pull the pedal back up?? if so this a sign of the clutch slave cylinder ready to go i had this problem and its very easy to change the part!
