Hi, everyone first time posting for me.
I've got a 1989 1.4L Tipo there are three white dots of paint on the cambelt pinion. The second dot (looking at the pinion face on counting clockwise) is accompanied by a groove cut into the pinion. There is about 14 degrees between the first and second. The cambelt inner cover has both the plastic moulded pip (as in Haynes) and a white dot. It's possible to align the first white dot on the pinion with the moulded pip and the notched pinion white dot of the second with the the dot on inner cover if the sliding cover is left down. Then if I lift the sliding timing piece the notch on the pinion coincides with the pip. I'm seeking confirmation from someone that the notch in the pinion has to align with the pip on the lifted inner cover when the crankshaft is at the 10 deg btdc.
Haynes doesn't specifically tell you to lift the sliding timing mark just a photo.
Purple Haynes all through my brain, lately things don't seem the same.
The third white dot is way back about 70 degrees from the first. I've got to assume this is a red herring or the whole car is a red herring suffering from white dotitis.
The original cambelt snapped (one valve replaced) so unsure of the original configuration. I've actualy tried both positions then I checked the valve clearences they seem OK so hopefully no valves are bent.
Should the camshaft swim in oil?
Haynes shows a a single white dot on the pinion, why can't mine?
At present the pinions set so the notch coincides with the pip on the lifted inner cover slider. There's maybe 1 or 2 degrees difference between the marks on the flywheel lining up and the notch with the pip for the camshaft. The best I could do - does it matter? The distributor rotor arm was aligned with no 1 lead. On cranking the beast wouldn't fire. I've tried with some help today we got a brief fire by cranking while he turned the distributor.
Things I noticed while doing the job was the linkage from the wax temperature
regulator in the air filter had come off - now re-fixed. Someones put a 1.6L carburettor on at some stage (according to the Haynes codes) using the inlet manifold for the advance retard vacuum and there's no drilling for the petrol return to tank - pipe's been bunged.
