Technical Tipo 2.0IE 8V won't start w/out gas
mfriis
Denmark
Hello all,
My recently acquired Tipo 2.0 Aut won't start w/out full throttle. It is now ~10 degrees outside. When it was freezing it started w/out any problems at all. Turned the key, and Wroom. Any ideas?
New parts:
Plugs
Intake filter
Gas filter
Exhaust manifold (1st. piece of actual exhaust pipe, not the die cast part)
Thermostat is steady at 70-something degrees no matter the load / revs.
Could it be the thermostat for the ECU?
Thanks in advance :) ,
Michael
I dunno mate.. but i had the same problem last summer with me 1.6 Carb. in the heat it would idle low then stall when stationary. and after I'd been driving around for long and stopped for a bit it wouldn't start without gas.
In the blistering cold it always started first time though... I dunno if I shold be thankful for that and pissed off bout the heat or just thankfull :confused:
