OK my Tipo is being a bit gay this winter, I dont know if its a winter thing or a K&N Filter thing because last winter it was fine when I had the normal Airbox.
When I start my car it starts first time but it IMMEDIATELY switches off (Stalls) Power lights are on and everything.
e.g the starter motor don't turn for ages, it turns on AND CUTS OFF (Stalls) straight away.
when it does get started its ok... then it will stall after a few seconds, slowly goes quiet then switches off.
If I press the Accelerator to the floor it sounds like its sucking in Air, the revs climb a bit then they drop suddenly and it stalls.
If I press the Accelerator softley the revs climb nicely, then if I press the accelerator some more the revs climb more then if I press the Accelerator to the floor the revs go through the roof and it stays on.
So now when I start my car in needs Technique. I gently put my foot on the Accelerator and turn it on and its ok but if I press too much or not at all it doesn't.
When its cold and I drive it I also have to give it gentle acceleration or it tries to stall but can't because its moving too fast to stall so sometimes I get jerks or one BIG flat spot for about 5 seconds before it begins to accelerate.
Once its warmed up its fine and will start properly after its been switched off and will accelerate like a mofo and put me bum further back in the seat but when its cold it just can't be bothered it seems.
Any Ideas as to what it could be? I'm guessing a Carburettor issue but I'm gonna ask here cause I don't know.
Mechanical Fuel Pump was changed about a year ago and last time I had a Fuel Pump problem it was a problem all the time no matter what the engine temp was.
