IndianaAndrew
- Joined
- Aug 13, 2012
- Messages
- 14
- Points
- 57
Hello All,
I am currently plagued with a non-running 1979 x1/9 1300. I have posted about it before but due to college and life was not able to work on the car since. The car decided to stop running after a week of rain and school where I was unable to drive it. It ran fine before that. We cleaned the carburetor and checked spark to the coil and I think at a couple plugs. The engine acted like it wanted to start first thing each time I would try and it used to start ASAP as well. Compression was also good I believe.
Now I am checking the third combustion requirement, timing. I am attempting to change the timing belt. This leads me to my first question and some good(ish) news. How do I remove the belt tensioner? I removed the belt and spun the tensioner and it sounded like a rattle can. Now, I cant get it off the mount nor the mount and tensioner off the bolt. Is it supposed to slide off the mount or is it a press fit? For either, I believe i need to raise the engine a slight bit. Can i simple unbolt the right side mount and jack the engine up the needed inch?
The good news is that I believe the cause of it not running was a packed mud dauber nest on the ignition pulley :bang:. Most likely making it run at a different frequency then the crank/cam. Either way, I hope it gets fixed when a new belt and tensioner bearing ship from across the pond.
Thanks for the help,
Andrew
Andrew
