Hi There.
I want to start by saying thanks a lot for all the help and info!!!
Well today I went out and bought a used needle valve, and seat for my carb, and switched this as well as the top of the carb. But I read in the x1/9 haynes manual that the float must be adjusted at certain mesurements, but i cannot beleive the figures that they have in the book, becase the last three carbs I have taken apart the float measurements are round about 35mm from gasket to fully open #1 (bottom of the float "float face", furthes end out) and closed round about 1-3mm #2. In the X1/9 book it sais that the float should have a traveling distance of 9mm and the lower measurement #2 must be 6mm, and upper 15mm #1 for the 1300, and for the 1500 the lower measurement must be 6.75-7.25mm #2. So I tried to adjust the the float to these measurements, but all of a sudden the car didn't want to pull at all (hesitating), so I returned it to the settings which it was to start with. #1 = 40mm, #2 = 1.5mm, so now I can drive the car.
Then I tried to adjust the timing, and turning the housing clockwards, I got rid of the high speed rpm problem, but then the timing makes a noise if I load the car (4. gear at about 40km/h) or pedal to the metal (timing knock). So I went for a drive tonight after dark, and saw that there was a lot of small sparks coming from the ign. leads, espesially from the HT lead coming from the coil. So tried to clean them off with some meths, but still they make sparks, so I better invest in new leads, and plugs.
The last thing I have done, and I am worried about is the jets. I have taken the whole carb off, and fittet new gaskets under the carb, facing the manifold. But then I thought that I could just as well check the jets, (main, ideling, and the emulsion tubes, but got confused by which sizes they must be... Taking from the left to the right (so I get this staight and confirmed) I'll call the one at the utmost left #1, standing behind the car, with the ideling speed screw facing you. #1 is the primary ideling jet, #2, the primary main jet, # Secondary Main jet, and #4, Secondary ideling jet. Is this correct? And could you tell me exactly what their function is, and most important what sizes they must be?
I have a mechanic friend who has had the car coupled to a testing station, but I'm not sure he knows to well what he was doing, because he said that the primary jet must be much larger, and used a small drill to make the hole larger... And even if this goes against all my beleif, the car drove there after, and went a little better, but this isn't my way of doing things.. So I went out and found some different jets, and tried a few, but at last I fitted the ones I had before. (wondering if the car got enough fuel, not burning the valves) The car always drove fine, but I'm wondering if I'm not missing out on some Hp's due to his tampering, and if this couldn't be the reason for my problems. In the end he couldn't get the car to be within the limitations/factors of the tesing machine in any case..
Thanks a million for you help. Hope soon to get my car in top driving shape again.
Marcel.
