When you rev up, is the engine actually revving up and the error is just on the positioning reading or is the engine sitting on idle?
What kind of TB do you have, electronic or on cable?
Well, it looks like it's a communication problem between sensor and ECU. You can check the wires from TB and pedal, make sure they are not interrupted. Check the continuity. Also, you can clean the contacts as they are probably oxidized.
In TB there is 6 wires.2 for stepper motor and 2 wire common for position sensors l and remaing 2 are output from the tp sensors.if there is any issue with this wires throttle postion in track1 and track2 will also not work right sir? But here when gas pedal is pressed position sensor in track1 and track2 shows the deflections in degree sir.only the throttle opening in % is remains 0.i already cleaned the connection sir.
