Technical Throttle angle - FiatEcuScan
ivanjuaric
I made diagnostic with FiatEcuScan on my Croma 2.4 MJET V20 and the "Throttle Angle" is constantly 5%.
The problem is that I have small power loss when the engine is cool.
From my understanding the throttle angle should be open if the temperature is less than 20 degrees - or if the request for power is significant? Am I correct?
If the throttle is closed and at the same time the EGR valve is closed it could make power loss (no enough air at intake manifold)?
EGR valve works fine once the temperature is above 20 degrees and there is no more power loss.
I will try during the weekend to check the contacts of throttle sensor.
Do you know if throttle angle sensor with FiatEcuScan works correctly on EDC16C39 / CF4?
The throttle angle on my 1.9 JTD 8V is also on 5% all the time.
Should make a graph during a run to see if there is any activity.
