Technical Think I have a problem...
Hampshire
Started her up this morning(her being the new fizz) and she strated fine but lots of white smoke, didnt think much of it till i finsihed doing the windows and could see it coming from under the car, bulkhead location... this would confirm why dad said he thinks a blow in exhaust, new one was recently fitted by previous owner at quickfit so could be a bad seal somehwere... but why all the white smoke?
Looking yesterday there was mayo in the oil breather pipe, but none around the cam when i took cover off, oil level is fine and she doesn't over heat.
EDIT just looked at a thread in the 'cento section. Seems that mayo around the oil filler is common in cold weather as is white smoke due to condensation. Hope thats the problem, but it still leaves me with a blowing exhaust
Craig
White smoke in winter (cold weather) is OK....blue wouldn't be :)
If you use car in town, cold weather, short trip...there will mayo...
as other said....check cooland level and check if it's bubling....
Everything will be OK (y)
