these any good?
these any good?
T
thomas
looking to spend some penny's on my new HGT155 and just woindered if any of these below products would make a worthy investment? and comments or advice from other HGT owners on what else is good would be cool too!
APEX suspension kit
Koni Suspension kit
Eibach Anti roll kit
Powerflex bushes
Pipercross viper with cold air feed
Supersprint backbox twin exit
Black Diamond drilled and grooved discs
Red Dot 40 groove discs
Tarox G88 discs
i spotted them on motorsportworld website
cheers!
>APEX suspension kit
>Koni Suspension kit
Both are very hard and will give a bumpy ride. As I've said previously, a new standard shock will be better than an old worn out 'uprated' one. Use standard type shocks and change them more often.
Stiffening the anti roll bar is great for track use only. On road it will make the car skittish.
>Powerflex bushes
VERY harsh ride and a motherfucker to fit.
Yup, worth a few BHP.
Get the whole system, not just a backbox.
NEVER use drilled discs on a road car, they can shatter if you hit a puddle.
40 groove discs are not for road use, they have less braking area due to the grooves so don't actually work as well as normal discs. 6 groove are for road use and are actually quite good.
>Tarox G88 discs
As above.
many thanks tom! it would appear the cheaper option is better for once just stick with standard bits on the whole. things is i will need a suspension kit for if i lower it to reduce the roll (and make it look badass of course!). where can i find the entire exhaust system tho and would it be worth superchipping/angel remap after the pipercross and exhaust system is fitted?
also any other owners got any ideas?
tom
**if i lower 60mm what shocks would you recomend?**
thanx
Best way to reduce roll is to lower the car.
After a viper and a supersprint system you should get a healthy result from an angeltune, don't bother with sueprchips are they are a bit poo for non turbo cars.
Anon, any shock will do, you don't need special ones.
Thomas. Have Great Times in your Heavenly Gorgeous Toy. Had mine a couple of years - totally standard and it still gives sends me into to Hearty Grin Time.
Shabash!
http://ozrics.co.uk/
1
7K
Dark Lurker
L
6
366
M
H
3
497
K
J
1
311
nigel dennis
N
